Idle problem
Isikhan
Type Auto: Bmw 2008 320i executive
Idle problem
Post by Isikhan »
so I have this problem for almost a year and I've been to 3 mechanics and they couldn't find the problem. My 2008 320i executive has a rough idle when its has been off for ~10 hours en the check engine light turns on. I've replaced the spark plugs, ignition coils, high pressure fuel pump, the normal fuel pump, engine chain, oil filter and I still have the same issue. Ive been using BMW's for the past 30 years now and iqm experiencing this for the first time. Could someone help me? Thanks for reading btw😉 I'll be waiting for an answer.
Tho-e90
Type Auto: E90 325i + E46 325i compact
Re: Idle problem
Post by Tho-e90 »
Did you check for an malfunction code whenever the light popped up? Even though you've checked a lot of parts, there are still lot of parts which can cause a problem like this. If you can post the error code it might be helpful
