BMW F11 530D LUCHT VERING PROBLEMEN
Mrme4u
Type Auto: BMW E39 530D
Post by Mrme4u »
Beste Allen,
hieronder mijn verhaal in het engels.
Dear All,
about 4 weeks ago my right rear suspension dropped as i expected as the airbag looked bad, I replaced the airbag started the car it lifted itself to normal ride height, but reading various stories i immediately ordered the solenoid valve for the compressor. about 10 days ago the entire rear of the car dropped down and I took the solenoid valve i purchased and tried to install it to find out it doesn`t fit it has a different shape i read that someone else had the same experience. on a previous post.
After this I got lucky someone selling a practically brand new complete Air Compressor
First i ad pictures of my compressor, than the new one also Carly OBDII scan results
After installing this compressor I started the car expecting to see the car rise and that`s it, unfortunately this was not the case to the contrary it remained to the ground.
i checked the fuse 182 it was blown so i replaced it and still it doesn`t rise I than saw a video saying to pull the height sensor fuse a small 5 amp fuse nr 152 i pulled it and placed it back still no party. I then checked the Compressor relay took it out it looks brand new so i put it back.
just to be sure i ordered a new relay will fit it once it arrives.
after this all i thought I disconnect the battery pole and see if that makes it rise still no party.
I scanned the system with my Carly OBD2 scan initially air suspension fault was showing later it went after clearing and see pictures attached
Than the almost brand new one
Return to “2010 - 2017 (F07, F10, F11)”
