Cali BMW 523i to M50b30
luminmiller
Type Auto: E39
Post by luminmiller »
Hi,
My name is Lumin and im from California, but own a company/live in Leidschendam.
I am building a m50b30 to drop into an E39 523i, and wanted to post a couple pics of my slow progress:
The water-pump is a Stewart unit and I will be installing a two speed electric fan to assist with the cooling system
I have had a lot of time on my hands this winter and just have always wanted to build a clean engine.
Out with the old (I was retarded and forgot to leave the leveler accessible:
The Pistons are finally done (Polished Ceramic coated tops, Dry-Film Sides, Teflon coated insides, and fully weight matched to .01 of a gram):
Sad Valve:
Happy valves:
And a painted power steering pump with a power pulley:
All rust is converted and ready for paint
Aluminum silver sure is shinny in the sun
I did a progressive wet-sand then respray.
I am happy with the results:
:ugeek: Thanks for all the help so far and I will post more when I get some internals put in the block.
Re: Cali BMW 523i to M50b30
I removed your other posting because they weer similar.
- WdePundert
RPieter
Type Auto: E36
Post by RPieter »
Man great stuff!!
What are the specs that you want to reach with this engine, torque, kW? Made any more progress?
Kevv18
Type Auto: 530i
Post by Kevv18 »
Wow! Great job!
macmaas
Type Auto: bmw 323i e36 coupe
Post by macmaas »
good work dude
Good job but why you didnt take een M engine when you put this much work in it?
twannnd
Type Auto: 330i
Post by twannnd »
Looks so awesome everything fresh and new.!
